jjrad27
- Jul 19, 2007
saint joseph,
Missouri
Hello I have searched your threads and not really sure still on my problem i just put my car together i bought and it has a b&m bushwacker commando fuel pressure regulator, forn mount intercooler, stage two clutch and the vacumn mods sone to where i am running a catch can from my pvc valve and the other nipple on the valve cover as well as all vacumn ports blocked except for the fuel regulator and i have my blowoff valve and wastegate teed into a port on the intake my question is this when at idle, i run my car and it rpms up and everything sounds good but my wastegate actuator wont move my blowoff valve makes the pssh sound and has a great deal of air expelling from it when it makes the sound I also have the gm maf conversion done to i took my wastegate off and it moves freely but it seems to be that it moves forward and not pulling is this normal almost like it needs air forced into it and not vacumn to make it work is this right and is the vacumn elimination preformed right i tried to search for a reverse vacumn but couldnt find any on the intake please help thank you i have a 93 talon tsi awd
