turbogabe03
- May 4, 2007
west chicago,
Illinois
ok heres my biggest problem now, i drove my 95 eclipse w/ 6-bolt back home from work(ran fine minor missfire) so i could swap out my isc motor, disconnected battery, upper intake pipe, fuel line to rail, coolant lines (on throttle body), and the connectors for isc and tps sensor. I removed the 1g throttle body, cleaned it and set the tps to spec, installed diff isc. then re-installed it and re-connected everything else how it was. I then reconnected the battery and keyed the car on a couple times (for fuel), went to start the car and now it just cranks and cranks forever. I saw fuel coming out of the exhaust manifold so i let it sit for a bit and removed my spark plugs and torched off all the fuel on them. I also checked for spark and its there at every cylinder...
.when removing battery i accidentally arched it with something....im not sure if it would affect anything like a fuse that i dont knowabout that would cause my car to do this. I swapped in the 6-bolt last summer and i know the timing is good, have been driving it for about 6 months with no major problems ( until now)....need help asap PLEASE!
