jim97gst
- 482
- 3
- Aug 2, 2002
Bethel Park,
Pennsylvania
My car in general idles pretty well. The only time I have a problem is when it's cool outside and the engine isn't warmed up. Under these conditions, when I push the clutch in, the idle drops really low and sometimes stalls the car. I just checked the ISC, and it tested good. From reading some other threads, it seems that the FIAV is likely the problem. Is there any way to test this? How difficult is it to replace? If I call a dealer and ask for an FIAV, will they know what I'm talking about? I can't find it listed in the service manual. All of the threads I've found are regarding how to block the FIAV. By the way, there are no boost leaks, and the throttle body shaft seals are good.
Thanks
Jim
Thanks
Jim
