Won't let me shift
RT-AWD
395
2
Apr 28, 2007
Norristown, Pennsylvania
Ok, im at the end of my problems to fix now (hopefully this is the last one). last night i pull onto my street and try to go into 2nd and it won't go, tried first no go same with all my gears. Now, there is no grinding at all just impossible to put in gear. then it finally went into 1st and i was ok but shifting seemed rougher. I know i need to replace my slave and master cylinders and they are being shipped now. Did one of the cylinders kickthe bucket or is my ACT clutch gone or the pivot ball?
Thats definatly a sign that your clutch disc is very low. Your master cylinder being out of adjustment could be the problem too. I had the same problem with my clutch. I bought the new master cylinder, bled it and adjusted the rod accordingly. Hopped in the car and everything was back to normal.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
