Turboeagletalon
- 104
- Sep 13, 2006
Lansing,
Michigan
ok i have a 95 eclipse gsx with a six bolt swop.
this is really weird. my motor is built with eagle h beam rods. and ross 8.5 pistons.
the crank was rebalanced. and I'm using red line f1 bearings
i was driving the car perfectly fine without a problem. when i blew off my oil filter.
i pulled over immediately. and had it towed home. did an oil change on it.
i put on a 3000th vr4 oil filter.
and 4.5 quarts of mobile one synthetic.
my motor only has 700 miles though.
i think the oil did it
when i go to start it . it hesitates like the timing is off. and when i do get it to run. it knocks really bad. when i crank it over by hand. it feels like the valves are interfering with the pistons.
im going to check the timing today, and see is my timing belt skipped some teath,
any ideas
any ideas
If in fact you did shut the engine down immediately, you shouldn't have any knocking issues. The only thing i can think is that after running out of oil, the pump lost its prime. This could cause the engine to run dry until the pump pulls the oil up.
