smokedeganja
- Apr 5, 2007
Edison,
New Jersey
Ok i looked around but i couldnt find anythign that related precisely to my problem. Let me start with when the problem first occurred. I was driving to my frineds house and i was low on gas and out of nowhere the cra just started sputtering really bad and wouldnt let me accelerate far past 1000rpm's. I thaught that i had possibly ran out of gas and sucked somethign up into the fuel filter or something else along the gas line. I had somebody bring more gas to me and i put it in and drove the car home in the bad condition that it was. Ever since then it has been sitting there. I think my turbo is shot because i burn oil really bad and the turbo whines when i give it boost. But that was a problem BEFORE this happened. Now ive tried stating it up a couple of times but it only sputtered and ran really rough as if it were only firing on 3 cylinders. Eventually once it got a little warm it would just shut off completely. I let it sit for a few months and decided to try again so i looked under the hood befor ei tried and realized that the whole time the intercooler flex hose from the J-Pipe was disconnected. So i reconnected it in hopes that it would run good but my alarm system wasnt working right and i couldnt start it so i compleyely disconnected the Viper alarm. There was only one inline bypass that i cut and reconnected so i dont think there is any other disconnections, i cant see any at all. SO i tried to start it after that and it turned and i could here it firing a few times but it wouldnt start. So i thaught i was low on gas and went and got 3 more gallons to pour in. After i put the gas in i tried again but it just turned with no combustion. Now im stumped and clueless as to why it wont start. Can anybody give me a checklist? BTW i open the spark plug cover and i noticed a pool of oil sitting in the corner and i have no idea how it would get there but it doesnt look good. Im assuming it could be one of VERY MANY problems or more. PLEASE HELP ME SOLVE THIS. Thank you.
. its okay though if you wouldnt have told me to check compression i never would have cleaned the plugs and still woulda been stumped. I also realize now that my compression isnt as bad as i thaught it would be. its moderate but not severely poor. THANK GOD. Now my final problem is replacing my P.O.S. EvoIIIGT turbo.(im burning a LOT of oil and the turbo whines when i try to give it boost, i was told the turbo is burning the oil because the bearings are worn) I hope im not going to far off topic but do u have any suggestions for a 50-trim that would mount on to the evoIII manifold? Thanks a lot this forum really made a difference!
