KRAUS
- Mar 4, 2007
fdl,
Wisconsin
I recently bought this car not running,92 awd eaagle talon 4g63 turbo dohc.It had a bad headgasket removed head found bad piston besides.Replaced all four pistons rods,all bearings rings etc.Put in new timing belt ,all tensioners, head gasket,had head checked and valve seals replaced.Drove car two days, ran perfect.Went to leave work the third day won't start,pulled plugs black on all four.Figured flooded no big deal put in new plugs nothing spits and sputters like want's to stat but won't.Pulled plug black again ,so I check fuel getting plenty.Check spark have bright spark on 1 and 4 bright spark,on 2 and 3 not so bright.Is it something as simple as a bad coil or am I over looking another senser.I am going to ohm the coils tommorrow to see before i shell out 160 bucks.Anyone think of anything I am overlooking...
This car was never moded before I got it,it is stone stock except for the exhaust I put on it at time of motor repair.
