wags122
- 81
- 6
- Jan 19, 2005
Snohomish Co.,
Washington
well i have been having a heck of a time with my car to say the least. At first the stock clutch burned and i was pretty strapped for cash so i purchased a xtd stage 4 clutch and also installed a new clutch slave cylinder. Install went fine got it running and 136 miles later i was walking again. So this time when i dropped the transmission the center hub was broke out of the disk and my master cylinder was shot. So i replaced the master cylinder and bought a slowboy racing street disc and kept the xtd pressure plate. the install went fine and i got it running again and at about 430 miles i pulled up to a stop sign and put the car in first gear and started to go and i hear a "pink" and some grinding and the car stopped again but this time its different when the clutch is out it shifts in and out of every gear fine even while running, but when you push the clutch in first gear go almost all the way to the radio like the gear isn't there just pushing the shifter into air. then you let go of the clutch and its right back. I am at a loss to find the reason i keep breaking clutches i haven't even got one broke it yet so there hasn't been any boost on them Possibly anything to do with the flywheel? possibly warp from slipping of the stock clutch? or is me spacing to get the flywheel resurfaced coming back to haunt me? thanks for your help and sorry for the long post buts its been a long 2 months
