get435
- Jan 3, 2006
WVC,
Utah
Ok so i drove home from work shut my car off to go to my other job (about 30min) and came out and car will not start 96 GST. You can hear the starter but it sounds like it may not be fully engaged. The belts are moving but it seems very slow. I tried to jump it and it had no effect. Checked to see if it had spark and it dose. Checked timing marks on cams and they are in line dose not look like from the cams side that it has jumped a tooth just replaced timing belt a week prior. I was reading in my car book and it said it may be the Cam positioning sensor, cam angle sensor I cannot remember exactly which one it was called. It also says that this will cause it to loose spark and/or fuel. I am going to pull the starter tomorrow and have it tested just to make sure it is good. The main question I have is dose the starter have any roll/tied into the motor getting the right amount of spark or if it going out, dose it cause the motor to not start? also has anyone else ran into this issue I have looked around and havent seen another article that completely fits this issue.
