Clutch and Idle
xi Talon ix
238
Nov 24, 2006
Hughesville, Pennsylvania
I just installed a new clutch in my 90 TSi AWD and drove it out of the garage and when I was pulling out I noticed a slight vibration in the clutch pedal. Could this just be a sign that it needs warn in? Also, my car when started won't idle right away. Usually it will bog down and shut off. But once it gets warm it will run fine. Need some help guys. Thanks
Could be break-in chatter. Did you resurface the flywheel ? If not, it could be warping or dirt on the surface. You should flush the hydraulic fluid and bleed the system, too.
Yes the car is stock. I had the flywheel resurfaced. Also, me personaly didn't drive the car with the stock clutch in it so I don't know what it was like. I have not launched the car at all and when I installed the clutch I got all new fluid in it so thats all good.
