turbo98eclipse
- 1,096
- 15
- Jul 27, 2004
northern,
New Jersey
Hey guys! i remember posting about this issue months and months back, but never finding a solution. I got some new advice/clues to what could be wrong today and wanted to run it by you.
To refresh you on the problem:
The car boggs. Actually, more of a stutter. At maybe 2500 rpms (light on the gas) everything is smooth. Go wot from there and the bogging begins. The higher the rpm when I start wot the less bogging there is. Listening to it, it sound like rapid puffs of air pumping through the back of the exhaust.
Now, the bogging only begun when I installed a new turboback exhaust. I THOUGHT everything was tight. But using seafoam revealed I had a leak someplace under the exhaust manifold (o2 housing area) Then I remember...I dont think I replaced the gasket between the o2 and the downpipe!
Even with the downpipe bolted tight to the o2, having no gasket would allow a leak (duh)..
To make a long question short... Would a leak between the o2 housing and the downpipe be significant enough to make the car hesitate?
thanx for any help!
Even with the downpipe bolted tight to the o2, having no gasket would allow a leak (duh)..To make a long question short... Would a leak between the o2 housing and the downpipe be significant enough to make the car hesitate?
thanx for any help!
