ivj
- 55
- Sep 12, 2006
Renton,
Washington
Ok this is sort of a continuation from this thread:
http://dsmtuners.com/forums/showthread.php?t=242780
I installed an MBC, and had a boost leak, loosing all my turbo's power. I bought some tighter hoses, and everything's fine now, turbo's boosting as it used to. However, the MBC has no effect.
Basically, if I unscrew the MBC all the way out (aka - boost to the full or no boost), my car drives just like it always did, the turbo kicks to 12 psi, and i feel the power. My TURBO IS BOOSTING even though it shouldn't!
Now, if I screw the MBC all the way IN (aka full boost) - there's not a single change. The boost is still the same 12 psi, and the car drives exactly the same.
This is how I have it hooked up:
Line #1, goes to the nipple coming out of the turbo, right below the inlet.
Line #2 goes to the wastegate actuator nipple.
There were no instructions with this MBC which I got off a friend (and it worked just fine in his car), but from what I've seen online and from all other MBCs constructions, I believe I have these hoses hooked up properly. They're all airtight, no leaks , so I'm kind of lost. Please let me know if there might be an error in my hook up.
The only thing I can think of, is my wastegate actuator is broken, and it's actually running full boost, but my 2g BOV leaks anything past 12 PSI, so my car stays drivable. If this is the case, replacing my wastegate actuator would solve the problem of always boosting, and replacing my BOV would let me go past 12 PSI (15 here I come
What do you guys think? Any other theories/suggestions? Where can I get the wastegate actuator?
.What do you guys think? Any other theories/suggestions? Where can I get the wastegate actuator?
