SPD CAT
- 30
- Dec 18, 2005
macedonia,
Ohio
I bought this car bone stock from the original owner, getting ready to do a serious overhaul on it this winter. recently the #2 and 3 cylinders shut down on me one night while sitting idle in a parking lot for about 6-7 minutes, i limped the car home and parked it, the next morning i go to start it and it runs on all 4 cylinders at idle and in gear for about 20 miles and then it shuts off the #2 and 3 cylinders again. Since then it hasn't run on all 4 cylinders. I changed the plugs, wires and the coil pack that supply power to the #2 and 3 cylinders. i gotta take it back to the local parts store to read the code again but i tested the ignition power transistor and it has power for all four cylinders, so far i've:
* changed plugs (new NGK plugs)
* new wires
* 1 new coil pack
* tested the ignition power transistor
* thrown a couple tools around
* doubted my decision on calling this an easy fix
BIG MISTAKE!!!* almost had a heart attack when i seen the price of the stock replacement coild and
realized there is no aftermarket coil for my car
i did search on this but noticed that guys are getting power but no fuel, i'm getting neither.
my haynes manual says to test the ignition power transistor with a 1.5 volt battery and tester, has anyone tried this also? i've searched around and seen that the CAS may cause misfire but i also noticed that CAS was used to describe the crank and the cam in the same thread, which one is it, i'm assuming they were talking about the cam angle sensor, anyway, i'm not quite at the point for getting my 6 bolt in but, i'd like to fix this asap and get it back on the road, any help whatso ever would greatly be appreciated, thanks in advance
what am i doing wrong or not doing?
I FIXED IT!!!!!!!!!!!!!!!!!!!!!!!! It was the ignition module! To make this a lot easier to find, if you have an advanced auto parts near by, the part number is 115131 and the brand is GP Sorensen i'm sure any other parts place can cross the number to a different brand, oh and the price for it is currently $104.44 I just wanted to let you guys know! Thanks for all your help and input
