90 6bolt into a 94
foreverinvayne
120
Mar 27, 2004
Kenosha, Wisconsin
Quick question hopefully... will a 6 bolt turbo engine fit into a 94 without many modifications like there is when putting one in a 2G? I'm about to pick up a cheap 94 and i want to put my 6bolt block in it from my 90 but i want to know if i'd have to follow a lot of the info when putting it into a 2G. I tried searching a bit, but since mostly all im looking for right now is just a yes or no or some kind of idea about it I figured I'd just post this question for now. (and yes, i know not everything will just transfer over and i will need to use some things from the 94 motor due to having some different components)
Dan,
If you consider your existing 90 engine a long block and use the CAS, TB, Coils, PTM and wiring from the 94 you'll be ok. Keep in mind that in '94 all the cars got CA style emmisions so you'll need to swap over the 94 EGR or you'll get errors from the ECU.
Steve
well, my engine is still good except for my valves... as in i was going to be using the 94's head with the 90's block. would that be just fine if i used the 94's sensors and egr and coil and whatnot?
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
