Accidently threw out a part
teevee
55
Apr 30, 2004
So Cal, California
During a recent fluidine radiator switch + AC condensor removal I tossed out the old radiator with a part still in it. :shhh:
It was the coolant temp sensor that plugs into the bottom right side of the radiator. Could I drive by simply blocking off the hole in the new fluidine? Since I have my slimline fans running off a different power source, and also are activated with a manual switch is it necessary to have it? If so I'll get a hold of a junkyard.
Haste makes waste. :notgood:
We've all done it at one time or another...:mad:
You need a dog to blame for these kinds of issues....:D
That switch controls the automatic operation of the radiator cooling fans.
If you have wired your slimlines directly to a switch, (no automatic operation), then just plug the hole with a bolt and copper washer, and be done with it.
If you've wired your fans parallel, switched and automatic, losing that switch means no automatic operation.
I've had a few street/strip cars that were hard wired, (no auto), and they worked just fine, :tease: provided I remembered to turn them on.
I see you live in so cal, (hot/occasional carnage/gridlock, etc..:p ) if you street drive this car, automatic fans will save you sooner or later, so it might be worth your time to re-install that switch.
I would probably rewire it for automatic and on demand switched, but I'm old and forgetfull....:shhh:
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
