launchgsx
- Aug 12, 2006
westport,
Massachusetts
i have a question about a 95 mitsubishi eclipse gsx, i have a little bit of oily residue in ic lines and throttlebody/intake manifold i was told to spray it all with brakecleaner and if idle raises i havea leak, i have done this repetedly no idle raise, is there a common place intakes leak or and ideas
also i have hita unlucky spell i order a nopi #1 downpipe eliminate cat, got it and went to bolt it up it was about 2.5 inch to long, brought it back they said it must have been a bad batch, now i got a new different brand, got pacesetter ceramic coated, now i installed this today it was rubbing againts oil pan and transfercase, now if im not mistaken if i drive it like that my exhaust will be junk in no time with the twisting , because it is firmly against it, and at the end of the pipe where it connect to cat/test pipe, will never line up with my catback it is at about a 45% angle towards drivers side door, anyone else ever come across this problem???? thanks
... thanks
