gsxrtalon
- 395
- 2
- Apr 23, 2005
Harrison,
Michigan
Just recently my clutch has been losing pressure. I have a act2600 and my clutch is usually real stiff and just lately after starting it up I go to push in the clutch and its way too easy and the engagement point is a lot lower than once before. I have noticed that my fluid does tend to get low. The biggest thing I have noticed is the HUGE spot of something or other under the drivers side dash, to the left of the clutch pedal by the kick panel. Looks like a real bad leak I would think. What are your guys thoughts, kind of common sense yes I know. Should I just buy a whole new master cylinder or try to fix the existing one. Thanks.
