1990FWDTSI
- Jun 24, 2006
saginaw,
Michigan
well im new here and this is my first turbo dsm. its a 1990 eagle talon tsi fwd and the problem i am having is that at idle my logger is reading 12-13* of timeing advance and anything above 3500-4000 rpm 43 on the knock sensor. at full throttle in 3rd gear im getting anywhere from 35 and 45* of timeing advance . all of these readings are at 10 psi of boost the only suporting mod i have is a fuel pump rewire K/N and a MBC.
what should the timeing advance and knock readings be threw the rpm range?
