Bad Idle
92Talon251
220
Sep 26, 2003
Fayetteville, North Carolina
My car has been running good lately but the idle is acting up again. I have a new BISS new gaskets around the TB. Checked all vacum lines all are connected no noticeable holes, the car acts like it wants to idle sometimes and other it doesnt. The car does not surge but if I LIGHTLY tap the gas pedle and hold while the care is idling it will climb to 1500rpms then drop off and then repeat the process most of the time. Also if I tap and hold the gas the car will rev freely with no surging. I checked the ISC motor a while ago(2 months) it was fine, havent checked it recently though. The only thing I did notice is the green wire that goes to this http://www.diamondstarmotorsport.com/maintparts_files/throttle-close-switch.jpg
has a tear in it, and I can see inside the wire. I also notice if I remove the wire from the throttle close switch while the car is running, the car does nothing as if it doesnt care, not sure if it is normal or not. Also both honeycombs in the MAFS are still intact as well. I am seeking any help or possable solutions, I will test this ISC motor when I get a chance to. Thanks in advance.
:talon:
