Where this at
SlowdsmGST
188
Jun 27, 2005
Jacksonville, North Carolina
I am install my turbo timer and it say Orange wire = to the Revolution signal. What are they talking about? Keep in mind this is a JDM turbo timer.
What turbo timer is it? Do you have a harness? Revolution usually means RPM but i highly doubt a turbo timer needs an rpm signal.
Its a R-spec JDM turbo timer Part # att244. I have spent almost two weeks installing this thing. Biggest pain in the world because its all in Japan writing. I was lucky to find a post in A Skyline Form. Heres what I have on it as far as information.
Here where the wires go to.
Red wire = 12v power source
Green Wire = ignition
Yelow Wire = Acc.
Grey wire = to parking brake
Black wire = goes to a body ground
Purple wire = Only used in Japan
Orange wire = to the Revelution signal (BIG on that)
I am still dong so research to see if I can find a better information on the wiring. Here is the Diagram that I found on the other form.
So where would be the best place to tap that wire in? I would like to tap into the ECU if possible but don't know the pin number.
