95_TSI_AWD_CHIK
- May 9, 2006
Rock City Falls,
New York
Ok, I think I need a little help here. I have a 95 Talon TSI Awd 5-speed and here are my mods...1gen fuel rail with 650cc injectors, adjustable fuel pressure regulator, 255 walbro, t3 turbo, ported and polished cast manifold, 2.5" custom O2 housing, 3" turbo back exhaust (no cat), 8.5mm wires, turbox bov, ingen intake, manual boost controller, safc II, autometer boost gauge, autometer air/fuel gauge, fmic (28x9x2) w/2.5" piping, 34mm external wastegate. Now here is whats going on, If i start from 1st or 2nd gear and wot, my boost in 1st and 2nd will only go to 16-17psi max., 3rd, 4th and 5th gear she goes to 20-22psi. and holds. its not creaping to 20 either, just goes there and holds throughout rpms. why wont she go there in 1st and 2nd gear??????? here are my S-AFC II settings.... my sensor type is set on Karman, my throttle point is set at 30% for Lo and 80% for hi. my rpm corrections are set the same for lo and hi throttle and are as follows.... 1000rpm is set at -15%, 1600rpm is at -17%, 2200rpm is at -20%, 2800rpm is at -20%, 3400rpm is at -20%, 4000rpm is at -21%, 4600rpm is at -22%, 5200rpm is at -22%, 5800rpm is at -22%, 6400rpm is at -22%, 7000rpm is at -22% and at 7600rpm its at -22% as well. I have not done any logging yet. any suggestions on my boost issues???? please???? and thanks in advance, Liz
