LilRedRocket
- 33
- Mar 3, 2006
London,
I was looking through the site and found something that caught my eye!
I copied and pasted it into note pad but you could use the link to get a better view.
http://www.dsmtuners.com/sub.php?page=laser1ga
90-91 Plymouth Laser Specs
Model Trim: RS Turbo / RS / Laser
Engine Code: 4G63T (turbo) / 4G63T (turbo) / 1.8L (non-turbo)
Engine Specs: 16 valve, 2.0L, DOHC/ 16 valve, 2.0L, DOHC /8 valve, 1.8L, SOHC
Turbo: 14b (13g a/t) / N/A / N/A
Horsepower: 195 / 135 / 92
Drivetrain: FWD / FWD / FWD
Pros:
Stock "6-bolt" blocks are believed to be immune to crankwalk
Better flowing cylinder head ports than 2g cars
Bigger connecting rods through 92.5 model year
Bigger intake manifold and (60mm) throttle body
Stock 14b turbo has most power potential (A/T cars came with smaller 13g)
'90 models came with air-to-air oil coolers
Steel BOV
Stronger suspension than 2g cars
Both LSD rear differential and ABS on 92 models and up
Cons:
Smaller exhaust manifold that cracks
Smaller O2 housing
Smaller 10.2" front calipers on pre 92.5 model year cars
Single-piston calipers on pre 92.5 model year cars
Weaker 3-bold rear differential
Pre 91 model year cars came with LSD or ABS, not both
Only some models came with an EPROM ECU
The worst ABS system among DSMs
Now does this mean the1990 plymouth Laser RS Non-Turbo car I own still has a turbo DSM engine in it just with no turbo hooked up?? If so how easy does anyone think it would be to turn it into a turbo??
any input would be nice
Pros:
Steel BOV
Cons:
Smaller O2 housing
