lasvegastalon
- 38
- Apr 26, 2006
Las Vegas,
Nevada
Ok...here is the thing... i'm not sure if anyone has ever made a comprehensive list of ALL the items (or at least MAJOR items...clutch master cylinder,fuild change, etc etc) you can do to your 1g DSM to improve your Shifting before having to rebuild the tranny. Reason is, my DSM shifted like CRAP when i first bought it ... ("all awd cars this old shifts like this"...if i ever find the guy who sold me the car....
)then, i replaced and adjusted the clutch master cylinder, replaced the fuild, and she gets into gear 100% better than were it was before (would have to start it in reverse cause there was NO WAY of getting there starting from neutral ). The question is, short of sending the tranny to SHEP (which i will do...just not yet) what else can be done to improve shifting (the main problem now is that she has trouble getting into 2nd gear without grinding from a 6500 rpm shift from 1st....and well, i need my 2nd gear! =)
:SIDE NOTE: (not as important as the first segment, but, why would i be getting a "code 24 vehical speed sensor" since my 1g isn't suppose to have a speed sensor {so said another post} and if i do have one, where do i find it?, and 2nd, my fuel gauge is pointing strait up and staying there, how would i problem shoot that one)....again, priority to the first segment of the post.
)then, i replaced and adjusted the clutch master cylinder, replaced the fuild, and she gets into gear 100% better than were it was before (would have to start it in reverse cause there was NO WAY of getting there starting from neutral ). The question is, short of sending the tranny to SHEP (which i will do...just not yet) what else can be done to improve shifting (the main problem now is that she has trouble getting into 2nd gear without grinding from a 6500 rpm shift from 1st....and well, i need my 2nd gear! =):SIDE NOTE: (not as important as the first segment, but, why would i be getting a "code 24 vehical speed sensor" since my 1g isn't suppose to have a speed sensor {so said another post} and if i do have one, where do i find it?, and 2nd, my fuel gauge is pointing strait up and staying there, how would i problem shoot that one)....again, priority to the first segment of the post.
