Eagle91
- Apr 29, 2006
Roanoke,
Virginia
History: Car ran fine until water pump blew out, (yes that's coolant all over the left side or the engine compartment). I had a mechanic replace waterpump as well as timing belt and all tensioners and pulleys while everything was apart.I'm pretty sure he installed the balancer shaft belt with shafts 180 degrees out. He swears he went by the books he had and that mine were installed by the dealer wrong when timing belt was replaced several years ago.
I now have major vibration that was not there before.
Main problem:
Shortly after getting the car back it wouldn't start again after I shut it off until the motor completely cooled down. It always cranks and started fine when cold but would not restart until it cooled off again.
Ran OK . . . a bit rough but OK like it needed new plugs, then completely died one evening. I had error codes for the CAS, ISC and TPS all at the same time.
Replaced ECU and inspected the old unit. Capacitors had been leaking as well as major components totally fried. Car still won't start after it warms up and I had no error codes after installing the new ECU. After motor got up to temp I shut it down and it wouldn't restart . . . still cranks like hell with the Optima battery but will not start. I haven't tried restarting again in hopes that I may save the new ECU.
What should I be looking for and is it likely that I've fried a new ECU?
HELP!
