braking system gurus please help (non dsm)
bugdoubt
100
May 15, 2002
Ok here is my problem It started to snow so i need to put my talon away for the winter. Well my beater's brakes are jacked. And I have to fix them in the next two days
1989 nissan maxima non abs
symptoms:
-one day justed lost all braking going 40 mph...i pumped the brake pedal and finally my front left wheel locked(whew!!!!)
-now if i pump the pedal the car will brake but it's the same front left wheel only (i know cause it locks)
-with the car turned off the brake pedal is firm
-With the car turned ON, the pedal goes straight to the floorand requires pumping to build up a firm pedal(momentarily)
any suggestions where to look first?
it has a booster, basically just looking for tips to start eliminating possibilities due to my time crunch
thanks in advance to anyone that helps.
bug
check the right caliper for leaks.....see if the piston boot has any rips....put brake fluid in right..start the car....pump the brake if it keeps falling to the floor....ur loosin fluid somewhere...jus look under the car for fluid.in the wheels n shyt...
Check to make sure your brake booster has a good vacuum line attached and that it's not pinched or has popped off. Also check to see if the booster will hold vacuum. If the rubber membrane inside has a hole in it, it cannot boost your braking pressures.
Aaron
More than likely, based on your description, you have a bad seal in the brake master cylinder. Plus, brake vacuum boosters are supposed to be firm when the car is off because the engine is not producing any vacuum for the booster. perfectly normal on that aspect.
The pedal will be firm when the car is off. if you hold your foot on the brake when you start the car, the pedal will depress slightly - perfectly normal. it's supposed to do that.
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
