dtl1218
- Apr 27, 2005
Raleigh,
North Carolina
Hey everyone,
I just got my 4g63t running in my '88 Mighty Max. I'm at least glad that it does run finally, but I have an issue to work out. I haven't made a boost leak tester yet, and that may help me diagnose this problem, but I wanted to post to see if anyone else has experienced this. I haven't gotten my engine idle speed set yet, because I need to work through this problem first if I want to save my ears. I have a very low idle right now, but the sound occurs when the engine passes around 500 rpm, and it continues up the range. If I rev the engine, the sound disappears while I am pressing the gas, but returns once I let off the gas and continues until the rpms drop below 500 rpm. It may be some sort of leak, but I'm not sure. I'm still new to these engines, I know now how to install one in a different vehicle, but this is the first problem I've ran into now that the engine is running. I've tightened all clamps very tight, and I came across another post while searching about a high pitch sound being related to throttle body gaskets or seals. If anyone can help me out, I would surely appreciate it. Plus, the sooner I can fix this problem, the sooner I can post burnout pictures here since I have the four stock wheels and tires that I replaced, and they're begging to be burned down!
Thanks for any help!
David
David
