domenico_169
- 428
- Sep 17, 2002
Edmonton,
K so here is the story:
monday the car woldnt start after work, started at lunch no problem, but then wouldnt start after,after some time it finally started. The car would just turn over, power was fine, it just wouldnt catch. The wedensday over night it was absolutely freezing, so the car wouldnt even turn over in the morning. So yesterday i heated the engine with a heater, and it would turn over just great, just wouldnt start. Tried boosting it, same thing, keeps turning over just wont catch. it seems that when you turn it over you can smell the gas. So whatg i did today was take out each plug and wire one by one, and insert the plug in the wire and try and turn it over to see if they all had spark, which they did. So it seems like i am getting spark to all of them, and it seems like gas is coming from the fuel pump. Also, I currently have a full tank of gas. A friend of mine says it could be flooded from all the time we tried starting it, he reccomended removing the plugs, removing efi fuse, cank motor, clean and dry plugs, re-install, and it should start. BTW this os on a 95 esi. also car does not have a block heater so i cant plug it in.
