taino787
- 42
- Feb 27, 2005
albany,
Georgia
97 GST Spyder
My problem started when I was driving my car about 60mph (I was not dogging it at all. just driving normal) While driving I heard a loud bang(like hammer striking metal) comming from the engine, followed by several popping sounds(like loose bolts in a coffee can) I stopped my car and looked in the tranny area and floor for any signs of fluid leaks, but no MT fluid was leaking.
It was late and I was just a block away from my house so I decided to drive the car slowly and park it at home. The tranny shifted fine, (but I did not go past the 2 gear.) I kept a slow speed because the popping noise gets worst with speed increase.
While at home I moved the car back and forth a few times and I have noticed thet the poping only occurs when I when the car is rolling.
On top of the popping, I can also feel a strong bump every rotation (feels almost like I had bump in my tire, but im sure I dont) I also noticed that the whole engine moves (small pop) at the same time that the bump occurs. All the noises stop when the car stops rolling. I lifted the front of the car and had my neiigbor put the car in gear and found that the noise comes from the transmission.
If I turn the car on and get into any gear, the noise will come back on as soon as I start taking pressure of the clutch, withgout the vehicle moving. Noise stops as when car is not moving or a few seconds after the transmissions is taken out of gear and placed In N.
Any ideas ???????
Any ideas ???????
