m1nd64m3
- 714
- 22
- Sep 17, 2003
Chicagoland area,
Illinois
My fans wont kick on even though the fan itself works(tested it). I would like to believe its the coolant temp sensor but on my logger it still reads the temperature. So what I would like to know is the coolant temp sensor what causes the fans to go on or does the ecu turn them on based on a temperature reading from the sensor?
I recently replaced the thermostat when I put a new motor in so that is not it either. Had the problem with new and old motor but same temperature sensor. I switched the relays around and still no luck with that either unless all my relays are bad, which I highly doubt.
I have searched around and still cannot get a definitive answer on weather its maybe an ecu problem or sensor.
