trbotaln
- 633
- 9
- Sep 7, 2004
hidden hills,
California
Whats up guys,
I am having a problem with my 92 GSX. The cars drives fine but the idle surges sometimes and the car will stall out every once and a while. The car has the stock MAF with the lower screen removed so maybe that might be a factor. I have already tested the following things:
Boost leak tested
Reset TPS and throttle switch
Tested the IAC valve
adjusted base idle with Biss and resealed it
recirculated BOV
EGR blockoff
cleaned throttle body
o2 sensor works fine
tested fuel pressure
It seems like the car is running lean as soon I shut the throttle. Any ideas?
Boost leak tested
recirculated BOV
EGR blockoff
