90_Talon_TSIAWD
- Jan 25, 2006
Amityville,
New York
I needed some help with my Talon TSI AWD, I was driving down a street ( i was stepping on the gas pretty hard and when i was going to shift into 4th gear it seems as if i shifted into 2nd gear(so it was a PRETTY TUFF downshift!!), After that the car has been making a noise like if the Clutch were loose or something, but the noise only comes on when lettin go of gas on gears 2-5 and in 1st gear it does it all the time, but whenever the car is being pressed on the gas it wont make it only when i let go of the gas, the noise is SOMETHING like a grinding in the clutch or as if something is rubbing or griding on each other while its spinning... The car still drives around and turbo kicks in perfectly but that noise has me worried cause I dont know what it can possibly be
... Any suggestions of what IT MAY BE OR WHAT IT IS...
Thank you!
-- Jonis
... Any suggestions of what IT MAY BE OR WHAT IT IS...Thank you!
-- Jonis
