baracuda645
- 82
- 2
- Sep 12, 2005
hamlin,
New York
Ok, I've got a 98 spyder shell that i've been putting back together. I have a Haynes and a Chilton manual but these referances dont get Spyder specific. My problem is that when i got the shell it came with no doors and the rear speaker covers (plastic) were removed with every thing else under it. (metal bracket, speaker, conv. top motor, seat belts) I've piece most of it back together and have gotten some doors from a 96 Talon TSi, which was close enough to use. I've got the conv. motor back in and i'm getting the bracket for the speaker shipped in. The winows in the back are posing the problem, i'm not sure how they are suppose to work. Do they go down when the top goes down? do they have a seperate switch, if so do they have there own motor? can someone take a photo of there setup so i can see what its suppose to look like or send me a link to a diagram? I'm also looking for seatbelts for the front seats. The mounting brackets are different than a hard top. Your help is much needed even if you can only give me some advice on were to look for replacment parts for a spyder. (i've already checked the classifeds here and called the mistubishi grave yard)
Thanks
Ken
98
Spyder Gst
Thanks
Ken
98
Spyder Gst
