Idling issue...
AnkurJ0217
Oct 26, 2005
Parsippany, New Jersey
I have an idling issue with my car. Upon start up in the cold weather, it does not idle; it varies constantly however below the 500 mark. Just purchased the car and only has greddy type s and intake on it. everything else is stock. I personally think its a vacuum leak somewhere but I cannot seem to find one. Are there other things I can check? I know the Bliss screw could be turned to raise or lower idle but the car doesn't idle.
Turning the BISS screw on a 2g dose nothing unless you have a scanner to alow for idle adjustment, sounds like you have a vac leak. Try doing a boost leak test...
http://www.vfaq.com/mods/ICtester....tc that has anything to do with the intake...
