Mits3gts
- 188
- Sep 30, 2004
bellingham,
Massachusetts
I just installed my EPROM ECU with a custom chip from DSMchips.com. The car runs so much better, idles perfect and everything.
One thing that concerns me is when I first start the car or just turn the key to the 'on' position the o2 voltage on my logger and my digital o2 gauge will read almost 3 volts and will slowly drop down to .20 and then start cycling normal (when the car is running of course). My fuel trims are perfect, just curious as to why the voltage will read almost 3 volts.
This only happened when I put this ECU in. Any ideas?
