josiah01
- Nov 8, 2005
colorado springs,
Colorado
I have read a LOT of info on this topic. Random misfire seems to kind of be a "car-specific" deal, and I'm having trouble diagnosing it for certain. Thank you in advance for your help. And now for the car:
97 GSX 5spd, lightened flywheel
1G block, 2G head, unsure which CAS, guessing its a 1G (bought the car already built)
T-28 turbo, custom FMIC, all hard piping, no obvious boost leaking
Stock fuel pump, injectors ( i don't boost over 14lbs set with MBC)
No tuning/logging software (yet)
Brand new plugs (didn't solve the problem)
8.5mm wires
Symptoms:
CEL turns on randomly, can't force it, not always on, after i reset it it takes a "while" to come on again.
9 out of 10 times it comes on in 5th gear around 60mph, when gently accelerating
Engine tone changes when CEL throws, when I accelerate the engine begins "thumping" similiar to the "machine gun" noise other users have described. Once the CEL goes, the car becomes unbearably slow, accelerates very slowly, still getting boost on the gauge but not the typical response (ECU retarding timing or something?) I don't know which code it throws (need to find somebody with a code reader) The car has done this periodically since I bought it, so I know it isn't a mod I've recently done (the FMIC and sparks are new).
Any thoughts are appreciated. I will provide any more detail that I can. Hopefully I described the symptoms appropriately. Thanks!
8.5mm wires
Symptoms:
Another neglected maintenance story for you guys... CHECK YOUR TRANSFER CASE LUBRICANT!!! They leak!!! I didn't read about that until it was a hunk of grinded metal!!! It sucked trying to loosen rusty exhaust bolts to get the transfer case off....
