pooploser1500
- Nov 5, 2005
kinney,
Pennsylvania
ok, heres my problem. or maybe i'm my own problem. but i just bought my first dsm, and loving it
except for the fact that i have oil all over my engine bay. when i bought the car, there was a flap on my exhaust manifold that was not hooked up to a part of my turbo , a long metal rod with a hole in the end ( can you tell i've never worked with a turbo). i hooked these things back together and went for a ride, not believing how fast the car was compared to before, it was pushing 14 psi, as opposed to maybe 6 or 7 psi before. after i hooked these things back together and went for a ride, i had oil sprayed all over my engine compartment, mostly on the alternator and power steering. wtf is going on here? do i need to replace a gasket somewhere?? i dont know anything about turbos, at all, all i know is that i now have that metal rod unhooked again and going slow again.
also, when im stopped, my car idles high, then low, high then low, high then low, and when i have my brake pushed in, it idles fine. also when i'm in neutral just rolling down a hill, it idles the same way. wtf is going on now? i would like to get this talon running up to par, obviously the person that owned the car before me didn't give a shit.
except for the fact that i have oil all over my engine bay. when i bought the car, there was a flap on my exhaust manifold that was not hooked up to a part of my turbo , a long metal rod with a hole in the end ( can you tell i've never worked with a turbo). i hooked these things back together and went for a ride, not believing how fast the car was compared to before, it was pushing 14 psi, as opposed to maybe 6 or 7 psi before. after i hooked these things back together and went for a ride, i had oil sprayed all over my engine compartment, mostly on the alternator and power steering. wtf is going on here? do i need to replace a gasket somewhere?? i dont know anything about turbos, at all, all i know is that i now have that metal rod unhooked again and going slow again. also, when im stopped, my car idles high, then low, high then low, high then low, and when i have my brake pushed in, it idles fine. also when i'm in neutral just rolling down a hill, it idles the same way. wtf is going on now? i would like to get this talon running up to par, obviously the person that owned the car before me didn't give a shit.
