Mike Marnik
- 349
- 6
- Mar 5, 2004
Omaha,
Nebraska
OK so i keep getting Barometric Pressure sensor, Coolant Temperature Sensor, and Air Temperature Sensor CEL's. If i Clear them they come back in that order if that means any thing. Also when this happens my knock sensor pegs out at 42-43 all the time the tps will not register any change in throttle position. All those sensor are on the same section of the wiring harness and i replaced the wiring that goes to the sensors on the thermostat housing and i replaced the coolant temp sensor. the knock sensor is also brand new and i check the tps with a ohm meter and its good. It also comes and goes it is strange it will run like a champ no cels for a few days then out of nowhere bam i get the cels and all those sensors and what not go out. I am at my wits end its gotta be something simple since its all on that section of the harness but i cant for the life of me figure it out please help me I'm away at college and want to get it fixed before i go back home tomorrow. thanks.
