kurupt
- 124
- Oct 23, 2002
Calgary,
Can anyone tell me why I am only running 6 psi after $3000 work to my car? I took the car (92 TSi) in for a timing belt change which turned into a lot more. What they did was changed the timing belt, bs belt, water pump, pretty much everything in the front case, then I had 6 bent valves and a warped exhaust manifold. Sent the head and the exh mani to the machine shop, planed the manifold. Put everything back together. Car runs mint now, used to miss at idle. Only problem is, I'm only running 6psi. Isn't that pretty low? I also have 3" downpipe/exhaust, k&n, aftermarket boost gauge. Can anyone offer any advice on where to go from here? Thanks in advance.
You're welcome.
Glad you found the problem though. If you are only seeing 10psi, you are still leaking a couple pounds. Stock is 11 or 14 or something. Don't recall but a search would reveal the answer I'm sure. It's been awhile since I've been sans boost controller.
