eclipsegsx1736
Supporting VIP
- 1,599
- 44
- Nov 11, 2003
Los Angeles,
California
When my engine is cold and I apply load (moderate acceleration, tapping gas in neutral), i hear a kind of ticking noise coming from around the timing belt area. It goes away once the car warms up, and ONLY happens when under acceleration. I cant find anything noticeable loose. It started after my last oil change, but I don't think it's related. The only change I made to the car was new oil and I added some Lucas Oil Stabilizer for the first time. But once again, I'm pretty sure this is NOT the problem. Other than this sound, the car runs just as it did before. Its fairly loud, a little louder than bad lifter tick. I know it's not lifter tick because I used to have it, and it comes from a different area and it sounds a little different than this.
Below is a link to a video of the sound. Note that the mic on my camera isnt very good, and had a hard time picking up noise from the engine and from the ticking. So when i pull the throttle cable to cause the sound, the camera picks up the ticking, but for some reason mutes all other sounds... I found another thread that I think may have the same problem and someone suggested the harmonic balancer, but it was hard to tell if it was the same problem.
http://s22.yousendit.com/d.aspx?id=0WMXVZSCS9XD00BORU8VCGARDB
anyway one grind was the clutch, and one was the throw out bearing aka clutch release bearing, but the tick is still a mystery to me, i think its the lifters and i think i will try to soak/clean them and see if this helps?
all that I still dont know whats making the noise!
