1.8laser90
- 336
- 3
- Jun 8, 2003
alliance,
Ohio
After i had my burnt up ecu rebuilt and put back in my fuel pump doesn't want to come on. It worked before i had the ecu rebuilt which is weird but i know the ecu isn't causing it to come on... But i did check the voltage back at the pump and when cranking the engine over it gave me 8.5-9 volts. i was told that the pump should have at least 12v. Any idea what would cause this, i tried using the jumper to pass the relay but it still didn't come on but, i saw 2 jumpers behind the battery so i might of used the wrong one... any tips or ideas would be great..
