AntiZeroTrip
- 64
- Oct 12, 2004
Creston,
Iowa
Ok this has gone on for too long and I could really use some help. My 1990 FWD turbo laser has been having starting problems. I get in and depress the clutch, turn the key to start and one of 2 things will happen.
1. The car will turn over, and start, and immeadetly die.
OR
2. The car will just chugg over and over like its trying to start but you never get a response from the motor you just hear it turning over.
Now in some cases if I keep the key held to start and give it gas it will start, but the second i let off the key the car dies, wether im giving it gas or not. I have to keep it turned to start for about 20 seconds while i hold the gas. after that it seems like the CEL comes on and the car will run fine.
I thought it was the EGR valve so i took it off and cleaned it out. popped it back on and it didnt change a thing. I thought spark or fuel, but if that was the case I would expect it to continue to cause problems when I drive it. but other than the boost not properly boosting (boost leak or maybe its on a limped fuel map because of the CEL) it will drive fine.
The only things i can think of now is a sensor of some sort. any help?
**UPDATE**
Ok I had the car in the shop and the CEL is from the knock sensor. there is n o apparent engine knock though. My mechanic was tinkering and driving the car and we found out that the MPI (multi port injection relay) which is located next to the ECU is clicking afrter the car turns over and starts, and when the MPI clicks the engines revs will drop and the car will die out. So, we are thinking that the MPI might be bad. OR we have suspicion that the ECU might be the main cause of it all and needs replacing. We hav not pinpointed it just yet. My new questions are,
1. does the MPI relay die off like that without warning?
and
2. Is there anything to give you forewarning that the ECU is going?
Help is appreciated. thanks
OR
**UPDATE**
and
I drove it home and im afraid to take it back out anywhere. so, what should I go about doing next?
