Quick C/E/L Question
TalonJohn94
590
4
Jan 30, 2003
Milwaukee, Wisconsin
I periodically get a check engine light, in many different conditions. When I check it with the datalogger, it just says: 02 Sensor. It LOOKS like its cycling fine.
Does anyone have an idea what the problem is?
Should I replace?
Try doing a resistance check on the O2 sensor plug. In your maintenace manual, there should be a quick guide on checking your O2 sensor. It will give you a rough idea if it's within specs.
Keep us posted if you resolve the problem. :thumb:
