blkGSTspider
- 124
- Jun 27, 2005
northridge,
California
yesterday i tried to install upper intercooler pipes and couldnt install it...
i took out intake and stock upper intercooler pipes and i put it back where they
were... after i put the stock ones back and i started the engine...
RPM goes down to almost to 0 and goes up and goes down and goes up
again....
it happens while im driving too...so i just check all the pipes and started car
again and again.... and it got normal.... but today, after the work, i was coming
through the parking and i tried to close the window but it didnt move and i see
battery light was on in gauge... i parked and turned off the engine and tried to
turn off the headlight but it didnt work.. the light is still on even if i turn it to OFF
and lights in the car and windows didnt work... i tought the battery was died...
so i started the engine to see if its wrong with battery but the engine was
turned on and RPM goes up to 2 and comes down really slow to 1 1/4 and
stayed... RPM should be in about 3/4... it was too high
so i turned off the engine, tried to disconnect the +line from the battery to
reset... i opened the hood and i saw spark from the + line and it got normal...
head light was turned off and all the light in the car and window was working...
i just reset it anyway and started the engine.... and samething from yesterday
happened....
RPM started to trippin again.... goes up and dow up and down....
damn... anybody know whats wrong?? leaking??? i checked all the clamps
and i tied them tightly...
please reply
thank you
again....
happened....
please reply
thank you
