and11200
- 47
- Jan 2, 2005
Milwaukee,
Wisconsin
I recently had a new tranny put in (the exact same as stock) but now I seem to be having some troubles with my car. When the car is off, the clutch pedal acts exactly how it should. It shifts into first, second, third, (fourth seems kinda iffy). When the car is on, however, the car whines while trying to shift into first (Metals rubbing?) and the car won't move. The clutch pdeal will also stick about half way off the ground. It goes down fine, and comes back up, but only part way. I was told by a couple local dsm'ers that it could be crankwalk. Its a possibility, but I know its over-rated. They also suggested replacing the master and slave cylinders. I know to check for leaks, but what else should I do as far as making sure that they're well intact? Any help would be greatly appreciated.
-Andy
-Andy
