hippy
- 322
- Jan 18, 2004
chtown,
Ok got a 91 laser turbo put it all back to stock even factory air filter
!! It had a 255 pump in it and was getting to much fuel. SO i put the stock pump back in and it still doing the same thing it starts fine, idles fine but when you give it a little shot of gas it bogs bad. Then whne you go to rev it up slow it will slowly rev up but has a point where it is breaking down or something. And bad smell of fuel took plugs out black as ####. I cannot figure out what it is???? I had the laptop on and everything looks perfect o2 is reading all injector s are working knock sensor is working. EVerything looks great. But it is fouling up the plugs big time. I noticed tonight that around the fuel pressure regulator is a little damp of that hose.? So now im wondering if the fpr is working?? i cleaned the plugs of and put them back in and i started it and u could give it a shot of fuel and it worked like it should perfect fo r a bout a minute then bvack to the same thing again. took plugs out again black as ####. What would you guys sugest to do next?? I do still have a aftermarket fuel filter on it but cant see that doin the problem???
