Streetracer0442
- 52
- Jan 5, 2004
Maple city,
Michigan
okay i did the little key on trick to get the codes for my check engine light. well it spit out cel 12 which says direct power input to pcm has been disconnected within last 50 key on cycles, is this a major problem and how can i fix it, if i can? also my car has been hesitating and losing power from 0 to 45, it seems to stutter and not wanna go. like its not getting fuel, i thought it could be the EGR valve, but it's usually only when you push the throttle more than half way down. maybe it's the fuel pump i dunno. any helps appreciated. thanks. oh cars an auto, no mods just air-intake, problems were happing before in-take was on.
