jamel16
- 417
- 572
- Aug 6, 2004
Richmond,
Virginia
I just bought a 1990 eagle talon TSI AWD, The guy I bought it from said that he did a compression check and three cylinders were at 124 psi and the fourth was at 48 psi. He also rebuilt the head and replaced the gaskets. What would you recommend? Rebuild the block with new pistons and rings or just replace that one piston since the service limit is 121 psi. I don't plan on running high boost or anything so can I just get o.e. pistons.
