jott5555
- 1,263
- 6
- Apr 10, 2003
salem,
Oregon
as i said i searched but couldnt find anything
i put a 90 6bolt in my 95gst, so i have done the method 2 rre wireing stuff and swapped the coil blue wires and swapped the pins on the ecu, exactally like rre said to. i have triple checked the wireing and it is all 100% perfect. so it IS NOT the issue.
the issue is it will crank over it gets spark, it gets fuel at the rail ( i pulled the line and turned it over and fuel spurt out), all 4 plugs have spark, but none of the injectors are putting fuel into the combustion chamber. i pulled the plugs and turned it over and there was no sign of any type of fuel in any of the cylinders.
all the parts are good i removed them all from a 90 gst i have driven for the last year. i drove it into the shop before i pulled the engine and it ran 100% perfect. so i know for a fact the cas and such are good.
so WHY THE HECK ARNT THE INJECTORS FIREING???
i would like imput please no bs, no do you have fuel, its the cas its the ecu ect. they have all been switched with known working ones. please help
thanks
jon
thanks
jon
