TT_Stealth
- Jan 23, 2005
Normandy Park,
Washington
I did a compression test today on the TSI, across all 4 cylinders it read about 125, The cars turbo spools but dont feel any boost. I have checked the wastegate already, thats operational, no boost/vacuum leaks anywhere, no evidence of water (blown head gasket) in the oil, and no steam out of the exhaust. I datalogged it and the Timing advance when I wasnt in boost read as high as 38 sometimes, then when I hit boost read around 28 or so, and jumps around. Nothing is consistent in the readings. O2 voltage is about the only thing that is consistent. Any suggestions on what might be going on?
