Idle Problems
LosiRacerX
41
May 30, 2004
cant tell, Texas
my car isnt idleing rite, it sounds like its gonna die off, its idles at 600 rpm its 90 laser turbo rs, wut could all b wrong
This is a common problem if you have a CAI or RAI and you forget to connect the vent tube from the valve cover to the intake. Now you don't need the tube, as long as the connection on the intake is blocked off. If that is not the case look into your throttle position sensor or idle air control valve, those are common culprits for this. Pm me if you have any questions. goodluck
Just look over all your vacuum connections. Make sure none of them have worked loose, or are leaking. If everything appears to be good, you could try and reset your idle with the BISS screw. VFAQ has a guide on how to do it if you don't know.
